Maintenance Schedules and Routines
Mar 4th, 2008
Is there a recommended set of maintenance tasks that should be performed on an LMS2.6 server.
I already have logrot setup - just wondered if there was anything else that needed to be done i.e. database compaction etc.
miheg Tue, 03/04/2008 - 08:13
  • Gold, 750 points or more
There's a whole list of things to be purged, old jobs, reports etc.
You may wish to include that as well
Cheers,
Michel
Paul Williams Tue, 03/04/2008 - 08:25
Do you have a set of instructions for what to do where....or at least a pointer in the right direction?
Or a list of the commands to run?
miheg Wed, 03/05/2008 - 02:19
I don't have access to the gui from where I am now and I can't remember a lot.
I'm sure if you type "Data purge schedule" in the help it will take you where you should go in RME -> Admin.
I would say keeping records for about 90 days is good practice.
Cheers,
Michel
