sla command and track object v12.4(15)
Mar 4th, 2008
Hi all,
I have upgraded my cisco router 857 to version 12.4(15)T3.
And when I try to use the track command it doesn't recognise it:
C857(config)#track 1 rtr 1 reachability
% Invalid input detected at '^' marker.
C857(config)#
I have created a sla object:
ip sla 1
icmp-echo X.X.X.X source-interface Dialer0
timeout 3000
threshold 3
frequency 3
ip sla schedule 1 life forever start-time now
And I would like to use it to check the default route:
ip route 0.0.0.0 0.0.0.0 dialer0 track 1
But I don't know how to associate sla 1 with track 1 in this new version since the router doens't recognise track command.
Could anyone help me?
Thanks and Regards, Fernando.
Edison Ortiz Tue, 03/04/2008 - 08:54
  • Hall of Fame,
    Founding Member
That's odd. I checked the Feature Navigator and IOS documentation and track is supported on that IOS.
I don't have that equipment with me but I have a router with 12.4(17) and it works quite well.
Can you walk us thru the online help?
How about typing track ? and post what's displayed ?
Proceed with the online help until you complete the entire command.
HTH,
__
Edison.
networkingib Tue, 03/04/2008 - 11:27
Hi Edison,
The problem is that track command isn't on the online help, it is unrecognized:
C857(config)#track ?
% Unrecognized command
C857(config)#track
C857(config)#?
Configure commands:
aaa Authentication, Authorization and Accounting.
access-list Add an access list entry
subscriber-policy Subscriber policy
table-map Configure Table Map
tacacs-server Modify TACACS query parameters
template Select a template to configure
tftp-server Provide TFTP service for netload requests
time-range Define time range entries
username Establish User Name Authentication
vc-group Define a Frame Relay VC group
C857(config)#
Really strange.
Regards, Fernando.
Edison Ortiz Tue, 03/04/2008 - 11:31
  • Hall of Fame,
    Founding Member
That's the list of commands available to you from the online help ?
Can you type show priv and post its output?
networkingib Wed, 03/05/2008 - 00:56
There is more commands, I only pasted the related part of the list, just to show you that track isn't in the list.
C857#show privilege
Current privilege level is 15
C857#
The privileges are not the problem, it seems like if track command will not be able to be configured but when I add a route I can use a track object, really odd.
C857(config)#ip route 0.0.0.0 0.0.0.0 dialer 0 ?
<1-255> Distance metric for this route
A.B.C.D Forwarding router's address
DHCP Default Gateway obtained from DHCP
name Specify name of the next hop
permanent permanent route
tag Set tag for this route
track Install route depending on tracked item
C857(config)#ip route 0.0.0.0 0.0.0.0 dialer 0 track ?
<1-500> tracked object number
I can use track objects but I can't create them. :-(
Regards.
Edison Ortiz Wed, 03/05/2008 - 10:37
  • Hall of Fame,
    Founding Member
Not sure what else to suggest other than trying another code or opening a TAC case.
__
Edison.
