802.1d e 802.1w mixed: are all the Vlans in Rapid?
Mar 4th, 2008
Hello to all, I have this problem:
2 switches:
Switch A 48 port in RAPID-PVST+
Switch B 24 port in 802.1d
Switch B is connected to switch A through port 1 in trunk
There are VLAN 2,4 and 8 in Switch A and only VLAN 2,8 in Switch B
The question is:
How is the behaviour of the rapid spanning tree on Switch A?... are all the VLANs in Rapid spanning tree on Switch A?...
I ask this because there is Switch B connected on port 1 of switch A in trunk in 802.1d
Best Regards!
Jon Marshall Tue, 03/04/2008 - 07:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
As far as i understand if vlan 4 is only on switch A and it is not allowed on the trunk port to switch B then rapid-pvst+ will run for this vlan.
For vlan 2 & 8 because they span both switches 802.1d will run for these vlans in terms of timers etc.
Note that if you have just pruned rather than cleared vlan 4 off the trunk then vlan 4 will also default to 802.1d timers.
Jon
