Bulk Changes in IOS
Answered Question
Mar 4th, 2008
I remember in catOS you could make changes to multiple ports with a single command. for e.g.
set vlan 99 2/1-6 etc.
So using the above as an example how would i do this in IOS?
Thanks a bunch.
Correct Answer by lamav about 8 years 11 months ago
interface range gigabitethernet 1/1 - 48
The spaces between the dash and numbers is necessary.
If so, pelase rate this post.
Victor
Overall Rating: 5 (1 ratings)
Correct Answer
lamav Tue, 03/04/2008 - 07:35
Victor
american1 Tue, 03/04/2008 - 08:18
Also:
-create a macro
Define interface-range int_range g1/1 - 48
-use the macro you created
Interface range macro int_range
Int_range represents a word describing the macro you created. The macro is saved in the run/start config.
ece344609_2 Tue, 03/04/2008 - 08:28
Thaks guys. I am assuming the macro is set per switch, would that be correct?
