EIGRP on 3560
Answered Question
Mar 4th, 2008
Hi, I want to configure EIGRP on a 3560 switch in order to eliminate static route redistribution. How would I do that. I can't find anything out there (documentation). What kind of port would that have to be a "no switchport" or a trunk? Thanks for the help!!!
Correct Answer by Richard Burts about 9 years 2 months ago
Bart
You can run EIGRP over layer 3 interfaces on the 3560. This could either be a physical interface defined as a layer 3 interface (not access port) or a VLAN interface. You would not run EIGRP on trunk interfaces (though EIGRP might be running on the VLANs passing through that trunk).
What you would do would be to configure EIGRP in global config mode (router eigrp ) and then under the routing protocol you enter network statements to match the interfaces (and subnets) that you want to include in EIGRP.
It really is not particularly different to run EIGRP on the 3560 than it is to run EIGRP on a router.
Rick
Overall Rating: 5 (3 ratings)
lamav Tue, 03/04/2008 - 07:55
  • Blue, 1500 points or more
Oh boy! What a loaded question :-)
You can read this link, for starters.
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfeigrp.html
As far as the kind of port....I think you're a bit confused.
But, in short, to create a routed port, which is what you would want to do so that you can send and receive EIGRP routing updates, you would enter the "no switchport" command under the interface configuration mode. That will convert the port from a layer 2 switched port to a layer 3 routed interface.
Example:
interface gigabitethernet 1/1
no switchport
ip address 10.10.10.19 255.255.255.252
no shut
router eigrp 100
network 10.10.10.8 0.0.0.3
If so, please rate my post.
Victor
bsudol79p Tue, 03/04/2008 - 08:14
OK, I have two layer 3 switches, one of them is connected to the router, and the switches are connected to each other. Should I also configure routed ports between the switches as well? Should I make the routed ports on the management vlan? We have vlan 1 configured a management vlan. Thanks again!!
lamav Tue, 03/04/2008 - 08:21
Hi:
You can think of it this way:
If you configure an EIGRP routing process on your switch, it is then a layer 3-enabled switch and you must have routed ports configured from which to send and receive routing updates.
If the switch remains a layer 2 switch, then traffic will be sent/received to/from another network device through the use of a trunk, which is a layer 2/switched connection.
As far as the management vlan, you will want to advertise that interface under EIGRP so that you can have a route to it for remote access.
Victor
Correct Answer
Richard Burts Tue, 03/04/2008 - 08:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Bart
Rick
Richard Burts Tue, 03/04/2008 - 08:29
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Bart
We are at a disadvantage in trying to give you advice about where to run EIGRP since we know so little about your environment, the topology of your network, or your requirements.
Your original post says that you would like to use EIGRP to eliminate redistribution of static routes. So I would start by assuming that you need EIGRP where there are static routes (and especially where there are static routes being redistributed - are there static routes that are not redistributed?). I might go further than that and assume that you also would want EIGRP running wherever inter-vlan routing is being done. This would allow EIGRP to know all the active VLANs and to assist in routing between them.
If you want us to tell you more than this, then you need to provide us some additional information about your situation and your topology.
Rick
Richard Burts Tue, 03/04/2008 - 10:24
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Bart
I have looked through the configs that you posted. While there is still a bunch there I have not looked at carefully, I believe that I understand it well enough to make some recommendations. The router is already running EIGRP, and it is redistributing static routes. But the route map that controls redistribution does not permit the default route. I suggest that the router should redistribute the static default route. If the router redistributes the static default and the switches run EIGRP then the switches will learn the default route and therefore will no longer need static default routes.
I also suggest that you run EIGRP on both of the switches. On both switches you should run EIGRP 10 and it should include network statements for:
network 172.18.0.0
network 172.19.0.0
network 172.20.0.0
network 172.21.0.0
network 172.23.0.0
If you do this then both switches will not need any static routes and will learn the networks that they need to do effective inter-vlan routing. and they will learn a default route from the router and will forward all traffic for outside to the router.
This will mean that most of the inter-vlan route will now be on the switches which will relieve some of the work that the router has been doing and will reduce some of the traffic that the trunk to the router has been carrying.
Rick
lamav Tue, 03/04/2008 - 10:50
I agree with Rick.
And I will add that you can remove the "network 172.23.0.0" statement from eigrp 10 on the router. The router does not have any interfaces in that network and will therefore not be advertising it anyway.
Victor
