IPM 4.0.0
Mar 4th, 2008
I try to use IPM 4.0.0 with IE7, I encountered problems with Monitor button, the graph does not appear, so I try whit IE 6 and then I have the graph but nothing to graph only the minutes on the graph.
Plus I don't have anything in the graph?
What's wrong?
I just test the Echo with a router running 12.2 IOS and the target is a switch with rtr responder enable...
karima.zaydi Tue, 03/04/2008 - 08:40
now I have the graph but it gives me latency time to 9000 ms, I run sh ip sla monitor statistics on the router, and the DNS RTT gives me effectively 9058 ms!!!.
Did I have to configure something or is it possible?
