ISDN Call out issue on Cisco 876
Mar 4th, 2008
I am trying to configure a cisco 876 (adsl with isdn backup router). I only want to use the isdn interface on the router as I am using a seperate adsl router and intend setting up hsrp between them so I dont have a single point of failure.
anyway when I try to initiate a call on the router I get the following error
*Mar 2 00:47:07.638: ISDN BR0 **ERROR**: process_bri_call: Outgoing call id 0x8
011 blocked
does anyone know why I get this? Here is a sh ver
ISDNBACKUP#sh ver
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(4)T8, REL
EASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sat 11-Aug-07 03:34 by khuie
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
ISDNBACKUP uptime is 23 hours, 53 minutes
System image file is "flash:c870-advsecurityk9-mz.124-4.T8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 876 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memo
ry.
Processor board ID FCZ1205121G
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
mchin345 Mon, 03/10/2008 - 11:55
  • Silver, 250 points or more
This is usually seen when the isdn switch has no route for the outgoing call which is others issue.
lamav Mon, 03/10/2008 - 12:00
  • Blue, 1500 points or more
Post all pertinent configs...
agent2007 Tue, 03/11/2008 - 02:42
Guys I believe its the IOS. you need to have enterprise version to be able to dial out which is completly ridiculous. who in their right mind is going to just buy a router with bri port just to hang a modem off it for out of band management especially seen as its a router aimed at a soho.
good going cisco
manjeshmichael Thu, 01/29/2009 - 23:45
Even I could see the same ISDN errors in 876 router. ISDN L1 and L2 are active, but ISDN calls are not going through.
We tried to connect this ISDN link to another router and used the same configurations. It was working fine.
I think there is an issue with IOS (Adv IP services and Adv Security).
Try to upgrade the IOS to Adv Enterprise service Feature set.
darkbeatzz Fri, 01/30/2009 - 02:20
I did and it resolved the issue. all other version of IOS for these routers only support calls in and not calls out
