Paolo Bevilacqua Tue, 03/04/2008 - 09:09
  • Hall of Fame,
    Founding Member
Which type of interface card is that ?
Can't you connect via SIP that would be the easier and most efficient ?
ougwuoke Tue, 03/04/2008 - 12:04
I miss typed. SR140 is the right FAX software. I do know that It is supported for Unified Communication Manager I was not sure If SR140 was supported on communications Manager express
Paolo Bevilacqua Tue, 03/04/2008 - 14:26
  • Hall of Fame,
    Founding Member
Should work fine. These software connect fax via T.38 that of course the router has.
