Warning message
ASA5510 booting issue ""tftp://10.0.0.20/asa722-k8.bin""
Mar 4th, 2008
I've ASA 5510 & upgraded new IOS through ROMM after that it was showing below outputs. why it is showing ""tftp://10.0.0.20/asa722-k8.bin" as a file instead of disk:0... Can anyone help me out this issue..
ciscoasa# sh ver
Cisco Adaptive Security Appliance Software Version 7.2(2) <system>
Compiled on Wed 22-Nov-06 14:16 by builders
System image file is "tftp://10.0.0.20/asa722-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 11 secs
Hardware: ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 64MB
BIOS Flash AT49LW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0 : address is 0013.c480.7ce6, irq 9
1: Ext: Ethernet0/1 : address is 0013.c480.7ce7, irq 9
2: Ext: Ethernet0/2 : address is 0013.c480.7ce8, irq 9
3: Ext: Ethernet0/3 : address is 0013.c480.7ce9, irq 9
4: Ext: Management0/0 : address is 0013.c480.7cea, irq 11
5: Int: Not used : irq 11
6: Int: Not used : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 100
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : 250
WebVPN Peers : 2
This platform has an ASA 5510 Security Plus license.
Serial Number: JMX0938K05Q
Running Activation Key: 0xa1043b53 0xb469aa4c 0x2072adc8 0xaa44ac1c 0x483bd493
Configuration register is 0x1
Configuration has not been modified since last system restart.
ciscoasa# sh flash
Initializing disk0: cache, please wait...Done.
-#- --length-- -----date/time------ path
62853120 bytes available (28672 bytes used)
ciscoasa# sh disk0
In disk 0 it is not showing any file so that while rebooting (after upgrade ios) it is not booting from flash. Following message i got while reboot
2 seconds. 1 seconds.
Launching BootLoader...
Default configuration file contains 1 entry.
Searching / for images to boot.
Error 28: Selected item cannot fit into memory
unable to boot an image
Failsafe booting engaged.
ÿ
Booting system, please wait...
Nmi Npx0 Dly P92 Sha0 Kbd0 Cmos Pci Dma0 PrtB Tim Exp Rfsh Geom Mem0 Mem1 Ebda Admgr1 Memmgr1 AdmgrEbda Sha1 Media Smp0 Brd2
CPUID=0F29, Flags=0004
P7INTEL: Test MC - Flags=0004, CPUID=0F29, Rev=002E [Load]
CacheCpu0 CacheBrd0 Driver PostDrv Dma1 Irq1 Vec Brd4 Time0 Kbd1 Speed Vid0 Par Com PciEnum Vid1 Brd6
8 seconds. 7 seconds.
thanks,
