Setting up LAN extension
For setting up a LAN extension between 2 geographicaly dispersed 6500 switches, the only configuration needed is VLAN trunk right? No need for channel group if I'm only using 1 copper link?
SW1
interface GigabitEthernet12/42
description LAN EXTENSION
switchport
switchport mode trunk
no ip address
end
SW2
switchport
no ip address
end
I want all VLAN's to be passed so I wont specify the allowed vlans...
Am I correct? Or am I missing something?
Edison Ortiz Tue, 03/04/2008 - 10:49
  • Hall of Fame,
    Founding Member
You aren't missing anything, you are correct in all counts. Good luck !
__
Edison.
