Paolo Bevilacqua Tue, 03/04/2008 - 10:48
  • Hall of Fame,
    Founding Member
Are you using cme ? If yes:
ephone xx
mac ...
type cipc
button ...
That's it.
Hope thys helps, please rate post if it does!
netflight Wed, 03/05/2008 - 01:04
ok!! but my softphone say "please select the lines you wish control" but did not give me any options. what i need to config on my cisco softphone ?
Paolo Bevilacqua Wed, 03/05/2008 - 02:25
  • Hall of Fame,
    Founding Member
Not sure what version is the sofphone you're talking about. Usually ipcp 2.x is used and there is no line selection menu.
netflight Wed, 03/05/2008 - 02:55
im using cisco ip softphone 1.3(3.0) and a router 2811.
