NAC - Block Messengers
Mar 4th, 2008
Hello everyone, I'm in the middle of deploying a NAC solution and I was able to find documentation whereby I can CHECK if certain services are running. I tried making a rule to check if the "Messenger" service is running so that NAC will ask you to disable it. However I have not been able to make it work. Has anyone accomplished this. Can someone tell me what are the steps to follow in order to achieve this??
Thanks for any guidance!!
lolayo_19 Tue, 03/04/2008 - 10:50
BTW
What I did is create a service check so that it will check for a service status named "Messenger" Based on this I create a rule which I associate to a Requirement which I finally apply to a role.
Even though Im sure I'm running the service, I can still get through posture assesment.
