VPN Re-install issues
nlisuzzo1
Whenever I try to start the VPN 4.0.3 client I get warning 201: neccessary VPN subsystem is not available. I was told that I need to re-install the client but I cannot remove or repair the client with out recieving the message: deterministic network enhancer - remove plugin failed followed by an installer information window error 1722, at which point the repair or uninstall stops. Any ideas would be appreciated!
husycisco
Level 7
Level 7
Hi Nicholas
First download and run the following tool. Then choose to remove VPN 4.0.3 client
http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
Then download and run the following and reboot the PC. Installation should start fine after reboot
http://files.snapfiles.com/localdl834/WinsockxpFix.exe
