Show Config Command options
Mar 4th, 2008
I've got a 4507R that when I do "sho config" or "sho run" it outputs the entire configuration to the screen instead of one page at a time. Is there a way to fix this? Application buffer fills up and can't scoll up to what I need to see.
Overall Rating: 3.5 (2 ratings)
Edison Ortiz Tue, 03/04/2008 - 14:23
  • Hall of Fame,
    Founding Member
Are you connected via the console to the redundant Supervisor? If so, that's an expected behavior. Connect to the active supervisor and the screen should stop one page at the time.
If that's not the case, then check your terminal settings.
Please post the output from typing show term
HTH,
__
Edison.
lamav Tue, 03/04/2008 - 14:49
  • Blue, 1500 points or more
JT:
At the privilege exec prompt (hostname#), type term len 30.
This will restrict the output to 30 lines at a time.
If so, please rate all helpful posts.
Victor
