Diego Vargas Tue, 03/04/2008 - 14:11
Hi Matt,
Well is pretty much the same, a couple of new features:
Features in Software Version 8.20
The following new features are supported in software version 8.20.
•Slow starting services through the least connection (leastconn) load-balancing method - Cisco Content Services Switch Content Load-Balancing Configuration Guide
•Using SFTP to copy files to the CSS including log files, running and startup configurations, profiles, scripts, and core dumps - Cisco Content Services Switch Content Administration Guide
You can find the 8.20 release notes here
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20/release/note/RN820_X.html#wp171185
Hope it helps!!
Diego M
