I dont have the PDM username nor password
tdalago911
My look over a Job and inherited a 4 PIX 515e, I have the telnet password, but not the PDM GUI username nor password.
How can I reset the PDM username and password.
Tdalago
2 Accepted Solutions
brettmilborrow
You can use the username of 'pix' and the password you use for telnet, or you can telnet to the pix and check the other users configured by using the 'show username' command.
kamran.awan
hi Tdalago,
you can define a user and password for your PDM accout in Configuration Terminal.
example:
PIX(Config)#username XYZ password XXX privilege 1-15 (as desired by you)
Command line Help For User Add:
username {nopassword|password [encrypted]}
[privilege ]
brettmilborrow
kamran.awan
hi Tdalago,
example:
[privilege ]
