Home Lab: Can "Router on a stick" be done on these equipment?
Mar 4th, 2008
Hi...I just got a 2924 enterprise switch today and would like to try out "Router on a stick" configuration. I believe the switch should be fine but am wondering if my router can do it. Here's the router's info:-
2611 with two built-in 10baseT ethernet port.
IOS - 12.2(17), file name - c2600-i-mz.122-17.bin
I found this link that says it is supported on the 2611 with 10baseT ports:
http://www.cisco.com/en/US/products/hw/routers/ps259/prod_bulletin09186a00800921e4.html
But my IOS version is the standard IP, not the IP PLUS. (The above document does not say IP or IP PLUS)
Does this meet the min requirement for the lab?
Thanks. - AC
Overall Rating: 4 (1 ratings)
lamav Tue, 03/04/2008 - 16:32
  • Blue, 1500 points or more
"Does this meet the min requirement for the lab?"
Alex, there's a quick way to find out. Try configuring the router for the router-on-a-stick and see if it takes the commands and works! :-)
I'll give you a sample config to go on...
Switch Config
vlan 100
name data
vlan 200
name data
interface fastethernet [interface number]
switchport mode trunk
Router Config:
interface fastethernet 0/0
no ip address
interface fastethernet 0/0.1
encapsulation dot1q 1 native
interface fastethernet 0/0.100
encapsulation dot1q 100
ip address 192.168.100.1 255.255.255.0
interface fastethernet 0/0.200
encapsulation dot1q 200
ip address 192.168.200.1 255.255.255.0
If so, please rate my post.
Victor
devang_etcom Tue, 03/04/2008 - 18:21
  • Gold, 750 points or more
as you have 10 MBPS interface you just need to check that are you able to configure the dot1Q encapsulation on your subinterface or not... as Cisco normal recommendation is to use the 100MBPS for doing intervlan routing so see if you can configure the subinterface with the dot1Q encapsulation... the same question I had when I was studying some thing but we configured the 10MBPS link with multiple subinterfaces and configured the dot1q encapsulation and it was working so try it...
regards
Devang Patel
alexmchau Wed, 03/05/2008 - 07:10
Thanks for the replies. I happen to have this bad luck with the switch. It won't power on today (it was working yesterday). I have the box opened and found the power supply is dead - no output. I temporary jumped 3 wires to two external power supplies (for +12 and +5, bypassing the internal power supply). I have confirmed the switch is working. I need to run to get some wires and connectors from Radio Shack to hook it up so I can run the lab. Will post result. Thanks.
ellendrew Wed, 03/05/2008 - 04:53
Configure a subinterface first and try to find out if encapsulation command is present.
Kevin Dorrell Wed, 03/05/2008 - 06:03
  • Green, 3000 points or more
For 802.1Q you will need IP Plus.
Kevin Dorrell
Luxembourg
alexmchau Wed, 03/05/2008 - 11:14
Bad news.
I fixed up the 2924 switch and started working on the 2611 router. The 12.2 image (non-IP Plus) does not even have the encapsulation command ! The only other IP PLUS IOS I have is 12.0(16a) so I put that on the 2611 router. When I was in config-subif, there is an encapsulation command but the only option is SDE (IEEE 802.10 Virtual LAN - Secure Data Exchange). No dot1q !!!
I think my IOS is not capable of dot1q. I'm not familiar with SDE. I'm wondering what it can do compare to dot1q or ISL ?
- AC
alexmchau Wed, 03/05/2008 - 11:19
Bad news.
I think my IOS is not capable of dot1q. I'm not familiar with SDE. I'm wondering what it can do compare to dot1q or ISL ? (I just did some quick internet lookup and it is an old standard, older than ISL)
Well, I'm wondering how much I need to drill onto "router on a stick" but I'm studying for CCNA and like to grab as much practice as possible. But I'm also a poor student and can't buy high end routers for lab. :(
- AC
Edison Ortiz Wed, 03/05/2008 - 11:24
  • Hall of Fame,
    Founding Member
Dynamips is your best friend http://7200emu.hacki.at/
HTH,
__
Edison.
alexmchau Wed, 03/05/2008 - 12:23
Thanks. I looked into that before but decided not to go that route. First, Dynamips requires you to have your IOS image (which I don't have the right one in this case). I'm also trying to put multiple Cisco equipments together and I don't think Dynamips can do it. To me, the best learning is to get my hands on real equipments.
At the moment, I may only be able to do inter-VLAN routing by using both interfaces on the 2611. Until I can shell out some extra money for a 2611XM/36xx on 12.4 IOS, I think I will have to compromise with what I have for now.
Thanks. - AC
