03-04-2008 06:23 PM
I have to give a strict priority to the IP traffic between RAD IPMUX11, but as I understand my config doesn't work (round-trip min/avg/max = 4/9/92 ms) :
2621_KRKZ#ping
Protocol [ip]:
Target IP address: 192.168.106.250
Repeat count [5]: 10000
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 10000, 100-byte ICMP Echos to 192.168.106.250, timeout is 2 seconds:
Success rate is 100 percent (10000/10000), round-trip min/avg/max = 4/9/92 ms
2801_TRKT#show policy-map interface fastEthernet 0/0
FastEthernet0/0
Service-policy output: SHAPER
Class-map: SHAPE_TRKT (match-any)
178431579 packets, 211551221854 bytes
5 minute offered rate 2237000 bps, drop rate 0 bps
Match: access-group 165
178431585 packets, 211551221746 bytes
5 minute rate 2237000 bps
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
75 (%) 0 (ms) 0 (ms)
7500000/7500000 45000 180000 180000 24 22500
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 178431590 1097835450 959224 1187521203 no
Queueing
Output Queue: Conversation 265
Bandwidth 7500 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 1138617/1223438515
(depth/total drops/no-buffer drops) 0/0/0
Service-policy : E1inIP_TRKT
Class-map: E1inIP (match-any)
138717940 packets, 205723994192 bytes
5 minute offered rate 2158000 bps, drop rate 0 bps
Match: access-group 195
138428388 packets, 205703718834 bytes
5 minute rate 2158000 bps
Match: protocol icmp
289554 packets, 20275358 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 136
Bandwidth 2350 (kbps) Burst 58750 (Bytes)
(pkts matched/bytes matched) 235109/347943319
(total drops/bytes drops) 0/0
Class-map: class-default (match-any)
39713637 packets, 5827229108 bytes
5 minute offered rate 78000 bps, drop rate 0 bps
Match: any
737527 packets, 84597022 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
03-10-2008 02:54 PM
Have you configured the access-list?.
03-14-2008 09:56 PM
Yes :
access-list 195 permit ip host 192.168.100.250 host 192.168.106.250
