How can I block certains callsfrom the specific FXS ports?
Mar 4th, 2008
How can i block certains callsfrom the specific FXS ports?
I have to block the use of dial-peer voice 9 voip from the voice-port 1/2, what technology shold I use? COR? but I can not find clear documentation for me, please help me thank you.
voice-port 1/0
cptone RU
timeouts wait-release 5
voice-port 1/1
cptone RU
voice-port 1/2
cptone RU
voice-port 1/3
cptone RU
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 244
port 1/0
dial-peer voice 2 pots
destination-pattern 241
port 1/1
dial-peer voice 3 pots
destination-pattern 242
port 1/2
dial-peer voice 4 pots
destination-pattern 243
port 1/3
dial-peer voice 5 pots
dial-peer voice 6 pots
destination-pattern 245
dial-peer voice 7 pots
destination-pattern 246
dial-peer voice 8 pots
destination-pattern 247
dial-peer voice 10 voip
description ---- Central Office ----
destination-pattern 1..
session target ipv4:192.168.254.1
codec g729r8 bytes 40
description ---- Town destination ----
destination-pattern 9[1-6,9].....
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 03/06/2008 - 08:51
i wrote this down for a customer of mine a few days ago, maybe this helps you:
name FXO1
name FXO2
dial-peer cor list out1
member FXO1
dial-peer cor list out2
member FXO2
dial-peer 1 pots
corlist outgoing out1
destination-pattern 9T
port 0/1/0
dial-peer 2 pots
corlist outgoing out2
port 0/2/0
ephone-dn 1 dual-line
number 101
call-forward busy 500
call-forward noan 500 timeout 10
cor incoming out1
ephone-dn 2 dual-line
number 108
cor incoming out2
javalenc
SludnevTN_2 Thu, 03/06/2008 - 16:38
Thank you all. As I understand, I can use COR only if I have IP-Phones and Call manager? From the config above you have permited the use of ephone-dn 1 only on dial-peer 1 pots, correct? But I do not understand how can I restrict the use of specific dial-peer voip on specific FXS port?
