FWSM boot partition
Mar 4th, 2008
Is there a way which I can find the partition the FWSM (v3.2.4) is currently booted into (cf:4 or cf:5).
I believe "sh boot device" command will tell you only the default boot partition. And this cannot say when you have reset the FWSM using "hw-module module <mod_num> reset cf:5" command. Pls advise.
