CVPN 3000 and TACACS+
Mar 4th, 2008
I'm just looking for clarification on this point: Once you setup a TACACS+ server in the CVPN you can no longer use the local admin user database?
Is this permanent? Is a factory default the only way to get the ability to use the local admin database again? Thanks in advance.
sdemlow007 Fri, 03/07/2008 - 12:29
Just FYI, I did get an answer from TAC about this. Here's how it went:
All via console (the local admin database will always be used for console access)
Remove the TACACS+ server
Add the same TACACS+ server back
Remove the TACACS+ server again
Change the user "admin" password
Now you are able to revert back to the local admin database for telnet & HTTP/HTTPS
Fairly simple process but, finding the actual procedure was a bit arduous.
