MARS 100E and 110R database compatibility
Answered Question
Mar 5th, 2008
Hello!
Does anybody know if I can use MARS 110R as a spare part for my 100E system for archive browsing. I mean that if I need to investigate a clause that is now in archive I need to deploy the whole database on offline MARS. Is it possible with 100E-110R pair?
Regards, Amir
Correct Answer by mhellman about 8 years 11 months ago
Maybe, using the following procedure:
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/4.3/migration/guide/dmigrate.html
I think you'd have to modify the process (add a few steps) to accomplish what you're after, but it seems plausible.
Personally, I think you'd be better off just manually searching through the archived data.
Overall Rating: 4 (1 ratings)
uralsib Tue, 03/11/2008 - 02:32
Hi!
Thank you for the idea - I think this is exactly what I need!
Regards, Amir
