Error with SoftKey on Phone 7960G
Mar 5th, 2008
we have a Problem with Softkeys on a 7960G Phone.
The following example works on a 7941G without Problems, but on a 7940G or 7960G I only receive XML Parse Error
<CiscoIPPhoneMenu>
<Title>Titel</Title>
<Prompt>Prompt</Prompt>
<MenuItem>
<Name>this is a menu item</Name>
<URL>url1</URL>
</MenuItem>
<SoftKeyItem>
<Name>exit</Name>
<Position>1</Position>
<URL>SoftKey:Exit</URL>
</SoftKeyItem>
<SoftKeyItem>
<Name>select</Name>
<Position>3</Position>
<URL>SoftKey:Select</URL>
</SoftKeyItem>
</CiscoIPPhoneMenu>
What can be the Problem?
Firmware:
7960G: SIP P0S3-08-8-00
7941G: SIP41.8-3-3SR2S
pklos Wed, 03/05/2008 - 15:33
  • Silver, 250 points or more
Try to change XML tags order for SoftKeyItem. I have sth like this and it works for 7960 and 7940:
mySelect
SoftKey:Select
regards,
PK
servicegk Thu, 03/06/2008 - 00:12
I have changed the order to:
Titel
Prompt
this is a menu item
url1
exit
SoftKey:Exit
select
SoftKey:Select
but no sucess, any other ideas?
pklos Thu, 03/06/2008 - 02:13
Hi, maybe you send Unicode (good for new java phones 7961, 7941) and 7960 needs ISO encoding and not a single char before ;). Please check it. If this is sth else please please upload your file (with correct url and so on).
regards,
pk
servicegk Fri, 03/21/2008 - 04:50
hello i have lookd over my files again and again, but I could not see anny problem. we are doing normaly more programming with the 79x0 phones (phonebooks, forwards, etc.) but the softkey feature seems verry tricky.
I will load up my file in this post, and if someone hase these softkey thing running, it would be nice if he can share these....
thanks for help
andreas koch
pklos Fri, 03/21/2008 - 05:40
Remove this line:
<?xml version="1.0" encoding="ISO-8859-1"?>
regards,
PK
servicegk Sun, 03/23/2008 - 02:33
Hi, If I remove this line, then I have the same code as we was starting in these thread...
The thing is if I remove the line relatetd to the softkey, the the code will work also on the 79x0 phones after inserting the SoftKeyItem again it will only work on 79x1 Phones.
Again...Please, hase someone a working example, that I may see if this will work on my side?
blakekrone Mon, 03/24/2008 - 19:51
I have been struggling with getting the SoftKey to work on the 7960 running SIP as well, from what I can read on other mailing lists and such is that the SoftKeyItem is not supported on these phones.
If you telnet to the phone and do a debug http you'll see the following:
[21:50:35:39017] ERROR: Could not find token SoftKeyItem in current element table.
