Skinny - getting all phones to ring at once
Answered Question
Mar 5th, 2008
I know that you cant get all phones to ring simultaniously when a call comes in (CME UC520 using skinny).. Ok.
I know I can give all of the phones the same number, Ie 202 on all phones and when someone calls 202 all relevant phones ring, BUT thats a little bit shoddy because when you want to transfer a call... where do you transfer it!! :)
Now, say I have ten extensions
200
201
202
203
204
etc
etc
Can I give those numbers a sort of 'secondary' number like:
200
201 secondary 200
202 secondary 200
203 secondary 200
204 secondary 200
etc.. do you see what im trying to achieve? So 201 202 203 are 'callable' by dialling their numbers, but if someone calls 200 all those phones ring.
Is this possible?
Cheers
Correct Answer by Paolo Bevilacqua about 8 years 10 months ago
When multiple ephone-dn do have the same number (primary or secondary doesn't matter), they will be ringing round-robin when said number is called, and will not ring simultaneously.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Wed, 03/05/2008 - 06:39
davieshuw Wed, 03/05/2008 - 06:43
aarggh. Ok i'll see if I can action that script you posted on another post, see if I can work it out!
cheers
Paolo Bevilacqua Wed, 03/05/2008 - 06:47
Beside the script, what is exactly the problem that you have with a shared line?
The most common problem is that subsequent calls to the shared line go only to the phone that is active, that is solved by chaining with call-forward busy multiple shared lines in overlay with call waiting, dn are configured with "huntstop channel".
Thanks for the nice rating and good luck!
rob.huffman Wed, 03/05/2008 - 06:48
Hey Paolo,
What about this setup with Shared Line overlaid DN's? Isn't this exactly how they work?
Shared-Line Overlays
Dual-line ephone-dns can also use overlays. The configuration parameters are the same as for single-line ephone-dns, except that the huntstop channel command must be used to keep calls from hunting to the ephone-dn's second channel.
The primary ephone-dn in a shared-line overlay set should be unique to the phone to guarantee that the phone has a line available for outgoing calls, and to ensure that the phone user can obtain dial-tone even when there are no idle lines available in the rest of the shared-line overlay set. Use a unique ephone-dn to provide for a unique calling party identity on outbound calls made by the phone so that the called user can see which specific phone is calling.
Shared-line Overlaid Ephone-dns: Example
The following is an example of a unique ephone-dn as the primary dn in a simple shared-line overlay configuration. The no huntstop command is configured for all the ephone-dns except ephone-dn 12, the last one in the overlay set. Because the ephone-dns are dual-line dns, the huntstop-channel command is also configured to ensure that the second channel remains free for outgoing calls and for conferencing.
ephone-dn 1 dual-line
number 101
huntstop-channel
ephone-dn 2 dual-line
number 102
huntstop-channel
ephone-dn 10 dual-line
number 201
no huntstop
huntstop-channel
ephone-dn 11 dual-line
number 201
no huntstop
huntstop-channel
ephone-dn 12 dual-line
number 201
huntstop-channel
!The following ephone configuration includes (unique) ephone-dn 1 as the primary line in a shared-line overlay
ephone 1
mac-address 1111.1111.1111
button 1o1,10,11,12
!The next ephone configuration includes (unique) ephone-dn 2 as the primary line in another shared-line overlay
ephone 2
mac-address 2222.2222.2222
button 1o2,10,11,12
From this good CME doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1099687
Maybe I'm lost here (no surprise :)
Huff
davieshuw Wed, 03/05/2008 - 06:52
well basically guys my problem is this.
Im putting a UC520 into our directors house. Its a biiig house.
He's going to be having around 12 phones (7941's and 7921's)
He's only got the one number.
So when he's in, say, the east wing, he wont hear the 'main' phone ringing in the west wing, so I wanted all the phones to ring so no matter where he was he could hear a phone.
Paolo Bevilacqua Wed, 03/05/2008 - 06:55
Shared line is your friend. I wrote the script only to address certain quirks, but just to answer from everywhere, is probably not needed.
Paolo Bevilacqua Wed, 03/05/2008 - 06:58
Yep, that's what colloquially called "chained-off DNs".
You usually want to use the "c" instead of "o" button when doing overlays, because it gives call-waiting.
rob.huffman Wed, 03/05/2008 - 06:59
Hi Huw,
Why don't you put the Shared Line on the first button (Line 1) of the 7941's and just configure seperate DN's on Line 2 for each so calls be be transferred to other ares of the house. The second Line will also be like an Internal Intercom :)
Rob
