cisco 5520: removed crypto map still in effect
Mar 5th, 2008
so i typoed a command: "crypto map Map1 7"... instead of "crypto map Map1 70".
I cleared the Map1 7 entries, and added the correct entries in Map1 70.
I cleared all of the vpn sessions:
no crypto map Map1 int outside
cl ips sa
cl isa sa
Now, however, whenever I try to ping the remote network from the inside interface, it seems to read the Map1 7 policy instead of Map1-70.
Is there anyway to clear the Map1 7 entries from memory? I'm trying to avoid rebooting the firewall.
Jeff
But when I try
Overall Rating: 5 (1 ratings)
michelcaissie Thu, 03/06/2008 - 10:26
With ASA you need the "clear configure" command to remove a crypto map sequence number
clear configure crypto map map-name seq-num
(in configuration mode)
