environmental conditions
Mar 5th, 2008
What is the meaning of operating temperature under environmental conditions mentioned in product sheets: If the temperature of the device that feels or the temperature of the room that switch works in?
lamav Wed, 03/05/2008 - 08:18
The environmental conditions refer to just that -- the environment in which the device is operating. There are heat sensors that meansure the temperature within the chassis. That heat is cumulative and consists of the room temperature and the the heat generated by the other modules.
yoguz Thu, 03/06/2008 - 00:20
then you mean that "show environment status all" command should show lower temperature values than operating temparature of device mentioned in product sheets?
I mean product sheet says it must be between 0 and 40C, but "show environment status all" output is 36-54C. Isn't it a problematic situation?
Thank you,
