vpn client and L2L
Mar 5th, 2008
Hi, I explain my situation.
I have a PIX501.
There is a vpn L2L and a person which connects to our network with vpn client.
Can this person connect to a pc which is behind the remote peer of the L2L using vpn client? If yes, how could I configure my Pix?
mvsheik123 Wed, 03/05/2008 - 12:26
If you are looking for the person able to RDP into the PC behind remote peer..yes..
you need to create ACLs for 'nonat' and 'tunnel' on both peers for the source/destination IP.
hth
MS
