Cisco to Juniper MPLS interop
James Lasky
I've connected a new Juniper MPLS node to my Cisco MPLS net.
The Juniper M320 is connected as Route Reflector to a Cisco 7206 PE.
Just making some test I see the problem that on the Juniper side I can't see what imported in the l3vpn from the Cisco MPLS world.
On the Cisco MPLS world I see what imported from Juniper but not viceversa.
MBGP is up, LDP is up, IGP is up...
Does anybody have any idea or knows if there is documentation somewhere in the web ? I wasn't able to find out anything on cisco.com and juniper.net
Pls advise
Ric
Ric,
You now see the routes in bgp.l3vpn.0, which confirms my theory. The reason they are not imported in vpn-test.inet.0 is that your import policy is imcomplete. You are actually missing the accept action in term a. It should look like this:
policy-options {
policy-statement vpn-test-import {
term a {
from {
protocol bgp;
community vpn-test;
then accept;
term b {
then reject;
This should take care of it.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
14 Replies 14
sergio.danelli
So is the Juniper a route reflector for the Cisco?
on the Juniper you have a routing instance with matching route targets as the Cisco?
some configuration and show command snippets will be helpful.
thanks
Ciao Sergio
Yes Juniper is a route reflector for the Cisco.
I'm quite new on Juniper, but I can paste some config... Keep in mind now I made a lot of test, hence something could be wrong...
Just a brief explaination of the environment: two PE connected via ge, Cisco has an internal vrf tsi already working, Juniper has an active subinterface (ge7/1/0.59) attached to a test vrf (vpn-test) but no active CE connected.
Importing on the M320 the rt 20608:600 (of the Cisco) I expect to see some routes on the table vpn-test, the same on the Cisco side (and I can see it on the Cisco!)
Have a look and feel free to put questions :-)
If you have any interesting document about Cisco to Juniper interop pls advise...
Tks
ric
Hi Ric,
I can't tell if you are advertising anything on the Cisco.
under router bgp 20608
address-family ipv4 vrf tsi
do a "redistribute connected"
Juniper does this automatically with the connected routes when you have a export target configured
That may do it, let us know if you are still having problems.
thanks
I did it, nothing changes...
hmm, weird just set something up and is working fine.
ON the juniper you have this output:
Table bgp.l3vpn.0
RIB State: BGP restart is complete
RIB State: VPN restart is complete
Send state: not advertising
Active prefixes: 0
Received prefixes: 3 <<< routes received
on the juniper paste a "show route table bgp.l3vpn.0 extensive"
That's it:
#> show route table bgp.l3vpn.0 extensive
bgp.l3vpn.0: 3 destinations, 3 routes (0 active, 0 holddown, 3 hidden)
{master}
Ric,
From the info you provided, it looks the Juniper device does receive 3 VPNv4 routes from the Cisco side:
Table bgp.l3vpn.0
Active prefixes: 0
Received prefixes: 3 <+++++
Suppressed due to damping: 0
The issue is most probably due to the fact that the next-hop is the directly connected interface between the two routers. JUNOS will consider invalid any VPNv4 routes for which there is not an LSP (route to NH installed in inet.3). In your scenario, there will not be a route in inet.3 for 217.172.8.14 since this is the directly connected interface.
In an MPLS VPN context, the BGP session should always be established to the loopback address of the PE rather than any of its physical interfaces. Many issues can arise if it doesn't.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
This is correct, but if the LSP was not built the route will be hidden:
lab@JuniperOlive# run show route table tsi
tsi.inet.0: 2 destinations, 2 routes (1 active, 0 holddown, 1 hidden) <<<<<<
+ = Active Route, - = Last Active, * = Both
30.30.30.30/32 *[Direct/0] 11:03:25
> via lo0.20
[edit protocols bgp]
lab@JuniperOlive# top set protocols ldp interface all
lab@JuniperOlive# commit
commit complete
lab@JuniperOlive# run show route table inet.3
inet.3: 1 destinations, 1 routes (1 active, 0 holddown, 0 hidden)
2.2.2.2/32 *[LDP/9] 00:01:03, metric 1
> to 10.1.6.67 via fxp2.0
No more hidden routes
lab@JuniperOlive# run show route table tsi protocol bgp
tsi.inet.0: 2 destinations, 2 routes (2 active, 0 holddown, 0 hidden)
20.20.20.20/32 *[BGP/170] 00:01:20, MED 0, localpref 100, from 2.2.2.2
AS path: ?
> to 10.1.6.67 via fxp2.0, Push 18
Something else is happening here.
On his output:
# run show route table vpn-test
vpn-test.inet.0: 2 destinations, 2 routes (2 active, 0 holddown, 0 hidden)
192.168.0.96/29 *[Direct/0] 17:52:37 <------- only the local routes!!!
> via ge-7/1/0.59
192.168.0.102/32 *[Local/0] 17:52:37
Local via ge-7/1/0.59
there isn't any hidden routes
Sergio,
You are correct. There were two issues here.
1. BGP on the physical interface instead of the loopback interface, which caused the routes to be hidden in bgp.l3vpn.0
2. Imcomplete import policy, which caused the routes nor to be imported in vpn-test.inet.0.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I tried to use the loopback, something changes!! I've now the routes in the bgp.l3vpn but not in the vrf vpn-test...
Cisco
#sh ip bgp summary
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
217.172.8.245 4 20608 12 67 0 0 0 00:03:30 (NoNeg)
#sh mpls ldp nei
Peer LDP Ident: 217.172.8.245:0; Local LDP Ident 217.172.8.251:0
TCP connection: 217.172.8.245.646 - 217.172.8.251.38821
State: Oper; Msgs sent/rcvd: 17464/15268; Downstream
Up time: 1d18h
LDP discovery sources:
GigabitEthernet0/0.308, Src IP addr: 217.172.8.1
Addresses bound to peer LDP Ident:
217.172.8.1 217.172.8.134 217.172.8.245
Juniper
# run show bgp neighbor
Peer: 217.172.8.251+38937 AS 20608 Local: 217.172.8.245+179 AS 20608
Type: Internal State: Established Flags:
Last State: OpenConfirm Last Event: RecvKeepAlive
Last Error: None
Options:
Address families configured: inet-vpn-unicast
Holdtime: 90 Preference: 170 Local AS: 20608 Local System AS: 0
Number of flaps: 0
Peer ID: 217.172.8.251 Local ID: 217.172.8.245 Active Holdtime: 90
Keepalive Interval: 30 Peer index: 0
BFD: disabled, down
NLRI advertised by peer: inet-unicast inet-vpn-unicast
NLRI for this session: inet-vpn-unicast
Peer supports Refresh capability (2)
Table bgp.l3vpn.0
Active prefixes: 3
Table vpn-test.inet.0 Bit: 30000
Send state: in sync
Active prefixes: 0
Received prefixes: 0
Advertised prefixes: 1
Last traffic (seconds): Received 4 Sent 13 Checked 4
Input messages: Total 67 Updates 47 Refreshes 0 Octets 7270
Output messages: Total 23 Updates 1 Refreshes 0 Octets 529
Output Queue[1]: 0
Output Queue[2]: 0
# run show ldp neighbor
Address Interface Label space ID Hold time
217.172.8.14 ge-7/1/0.308 217.172.8.251:0 12
# run show route table vpn-test (always only the local...)
192.168.0.96/29 *[Direct/0] 1d 18:31:09
> via ge-7/1/0.59
192.168.0.102/32 *[Local/0] 1d 18:31:09
# run show route table bgp.l3vpn.0
bgp.l3vpn.0: 3 destinations, 3 routes (3 active, 0 holddown, 0 hidden)
20608:600:53.212.0.0/21
*[BGP/170] 00:18:39, MED 0, localpref 100, from 217.172.8.251
AS path: ?
> to 217.172.8.14 via ge-7/1/0.308, Push 36
20608:600:217.172.1.248/32
AS path: ?
> to 217.172.8.14 via ge-7/1/0.308, Push 37
20608:600:217.172.28.0/24
AS path: ?
> to 217.172.8.14 via ge-7/1/0.308, Push 19
Ric,
policy-options {
term a {
from {
protocol bgp;
community vpn-test;
then accept;
term b {
then reject;
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks both of u a lot for your efforts.
Now it's working.
Tks
Ric
Harold,
Nice catch on the policy, totally missed that.
Ric,
by having the vrf-target command it makes it so you don't need the vrf-import in there.
vrf-import vpn-test-import; <<< redudant
vrf-target {
import target:20608:600; << of this, or vice-versa
export target:20608:4120;
vrf-table-label;
vrf-import gives you flexibility with policy, but vrf-target shortens the steps necessary in configuration, and imports all the routes with the route-targets configured.
anyway, im glad you got it fixed.
Ric,
Just to add to Sergio's point, vrf-import actually overrides the vrf-target import when both are configured.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
