IP telephony
Mar 5th, 2008
I want to install a telephone for people service, that when they take off the phone automatic dial the contact center, and they do not have permit to call another place.
I have a 2801 with FXS then it goes to the central ccm.
Alejandro Corte... Wed, 03/05/2008 - 10:50
Hi Zin, I have a 2801 router with 4 FXS and I want that FXS 1 be a hotline I try:
voice-port 0/0/0
connection plax xxxx
but does not work
Jaime Valencia Wed, 03/05/2008 - 22:05
do you have a dial-peer that matches what you're using as XXX in connection-plar?
do you get dial tone if you take out the command?
what is exactly happening?
you pickup the phone and what happens?
javalenc
