MMS:// port 554 with ACNS
Mar 5th, 2008
I have my CE setup and have the wccp setup on my router. I see that WMT is being redirected if I use http:// to access the video. If I try to go straight to the video using MMS:// (Windows Media Service) it plays from the original site not the CE. MMS:// uses port 554. Is there a way to redirect traffic based on this port number? How can I get the MMS:// request to redirect to the CE?
Diego Vargas Wed, 03/05/2008 - 08:59
So you have the router and CE configured with WCCP service 80 and 83? (for WMS 9 which uses WMT RTSP)
And you already have the license for WMT?
It sounds to me that you have web-cache service configured but not WMT RTSP services.
Hope it helps!!
Diego M
rclemenger Wed, 03/05/2008 - 09:56
when I do a show wccp services I get
WAE-512#sh wccp services
Services configured on this Content Engine
Web Cache
RTSP
WMT
MMSU
I dont't have a WMT license but I do have WMT enabled and am using the evaluation. A little over 16 days left on the eval.
Diego Vargas Wed, 03/05/2008 - 10:13
Do you have all those services configured on the router?
Can you provide the CE and Router current configuration?
Diego Vargas Wed, 03/05/2008 - 10:48
Are you using WMS9? Starting with Windows Media Services 9 Microsoft decided to use RTSP-based streaming instead of the previously used MMS.
From the docs:
With WMS 9, Microsoft introduced a major change in the streaming protocol. Windows Media Services 9 Series by default uses a new RTSP-based protocol for streaming.
These are the streaming protocols currently used by Windows Media 9 players:
•Windows Media Services 9 Series RTSP/RTP-based protocol
•Windows Media Services 9 Series-over-HTTP
A Content Engine, which is running the ACNS 5.5.1 software, has full interoperability with the Windows Media 9 server and a Windows Media 9 player over all of these streaming protocols.
So if you want to configure WMT in ACNS 5.5 you need to enable service 80 and 83
Take a look at the procedure:
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/acns/v55/configuration/local/guide/wmtstrm.html#wp1040956
Hope it helps!!
Diego Vargas Wed, 03/05/2008 - 10:49
BTW, you have service 80 and 81, so then again if you have WMT RTSP (used by WMS9) you need to have 80 and 83 configured.
