7940 phone and software vpn client
Rajesh Revuru Wed, 03/05/2008 - 08:26
No, it is not possible to use software VPN to connect 7940 from remote location.
You may consider
Cisco 8XX router
Cisco ASA 5505
The above devices are capable of setting VPN tunnels to headend VPN concentrator, and they also have 4 port switch thereby you can conenct your 7940 phone.
