Disabling Flow Control on 2851
Mar 5th, 2008
Does anyone know how to disable flow-control on a 2851 Gigabit Ethernet interface? I do not want pause frames being sent to the switch which has flow-control turned off.
Mike
Joseph W. Doherty Wed, 03/05/2008 - 18:40
I might be mistaken, but I thought pause frames were only sent if the other side confirmed it understood them.
mikepinto Thu, 03/06/2008 - 06:32
On switchport, the following line appears:
input flow-control is off, output flow-control is unsupported
Joseph W. Doherty Thu, 03/06/2008 - 07:35
Appears then that flow control was not negotiated to be active?
