lamav Wed, 03/05/2008 - 10:46
  • Blue, 1500 points or more
Mike:
A bounded update is a triggered route update that is sent only to those routers that need the information. The purpose is to conserve bandwidth.
Victor
Richard Burts Wed, 03/05/2008 - 10:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mike
To supplement the answer from Victor it may help to understand "routers that need the information". The thing that makes the update bounded is usually summarization or perhaps route filtering. The update is propagated to all neighbors who should know that particular route. But at the point where that route gets summarized or that route gets filtered out then there is no need to advertise that prefix any further.
Rick
lamav Wed, 03/05/2008 - 11:00
Rick:
can you clairfy "who should know that particular route"?
Can you post a configuration example?
Victor
Richard Burts Wed, 03/05/2008 - 11:25
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Victor
For example
interface Fast0/0
ip address 10.10.10.1 255.255.255.0
router eigrp 10
network 10.0.0.0
This will generate an advertisement for 10.10.10.0/24 to all neighbors of that router (they should know this route). Those neighbors will advertise that route (prefix) to their neighbors (they should know this route). Now assume that one of these neighbors creates a summary address for 10.10.0.0/16 on its interfaces. The neighbors out those interfaces have no need to know 10.10.10.0/24 but instead will need to know 10.10.0.0/16
Alternatively perhaps some neighbor has configured a distribute list to deny 10.10.10.0/24 out some interface. The neighbors out that interface do not need to know that route.
Does that help?
Rick
lamav Wed, 03/05/2008 - 11:36
OK, that clears up that.
It's a language thing, you know...the words chosen...
As far as "need to know" routes, I guess it would be better stated as "allowed to know". IOW, the neighbors out that interface are only "allowed to know" the summary route.
I know it sounds like hair-splitting semantics, but in this case, a slight change in the words can confuse the issue considerably.
Victor
Richard Burts Wed, 03/05/2008 - 11:57
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Victor
I absolutely agree with you that language and semantics are very important and frequently how we say things (the words that we choose) may help to clarify or may cause confusion.
I can see the alternative of describing it as "allowed to know" but I believe that there is a sense in which "need to know" is quite appropriate. In designing the network someone decides that certain neighbors need to know a certain level of detail (so that they will make appropriate forwarding decisions) and that other neighbors need to know less detail and will still make appropriate forwarding decisions.
[edit] As I think about it part of where I am coming from is an aspect of decision making theory that asks: how much information do you need to make the right decision. I believe that underlies the appropriate design of the network.
Rick
lamav Wed, 03/05/2008 - 12:02
Whatever floats your boat ;-)
ruwhite Thu, 03/06/2008 - 05:45
  • Gold, 750 points or more
Typically, we speak of bounded queries, not bounded updates.... Maybe that adds to the semantic muddle.
Russ
Mohamed Sobair Thu, 03/06/2008 - 06:26
The bounded update, is done when eigrp stablishes neighbor relationship, and whenever there is a changes on eigrp (periodic changes) and its a reliable.
the Query and the reply are also reliable handled by RTP.
Mohamed
