Site to Site VPN. ISP Change Issue
Mar 5th, 2008
Hi All,
I have site to site vpn established with one of my client office. The client is changing their ISP now.
I am wondering whether I need to delete the existing site to site vpn and recreate a new one with their new public IP address or do I just need to change the existing peer public IP with the new IP they are changing to.
Also can someone let me know, what command should I use to delete the existing site to site vpns
I am using Cisco PIX 515 with 7.2 OS running
husycisco Wed, 03/05/2008 - 12:12
Hi Chandru
Since tunnel-group name must match the peer IP, you should delete the tunnel-group and re-create it with the new peer IP.
Only entry is the peer IP entry in cryptomaps to change, no need to start from scratch. So what you have to do is...
1)Copy and paste your tunnel-group contents to a notepad, change the name to new address, type "clear tunnel-group oldIP" or "clear config tunnel-group oldIP" or "no tunnel-group oldIP". Then paste the modified entry in notepad.
2)Change the peer IP in cryptomap entry
no crypto map outside_map xxx set peer oldIP
crypto map outside_map xxx set peer newIP
If you like, post your current config and new IP of remote peer, and let me suggest you the exact changes
