Multipoint frame relay traffic shaping ?
philipbarker
I configure a hub & spoke topology with the hub as a multipoint interface and the spokes as physical. Is there a way to configure traffic shaping on a per PVC basis ? Or do I need to opt for point-to-point to achieve this ?
Phil.
Indicates static. The first command was there in the original configuration. The second command was added when implementing frame-relay traffic shaping. You need to place the shaping class under the interface-dlci subcommand.
philipbarker
Found out how to do this with :
under the frame-relay interface-dlci command using 'class' command.
Phil.
Edison Ortiz
Make believe you want to allocate 128kbps to Spoke2 and 192kbps to Spoke3.
Config at the Hub:
interface Serialx/x
no ip address
encapsulation frame-relay
serial restart-delay 0
no fair-queue
frame-relay traffic-shaping
interface Serial1/0.1 multipoint
ip address 192.168.123.1 255.255.255.0
frame-relay map ip 192.168.123.2 102 broadcast
frame-relay map ip 192.168.123.3 103 broadcast
frame-relay interface-dlci 102
class DLCI102
frame-relay interface-dlci 103
class DLCI103
map-class frame-relay DLCI102
frame-relay cir 128000
frame-relay bc 12800
map-class frame-relay DLCI103
frame-relay cir 192000
frame-relay bc 19200
Verification:
Rack1R1#sh frame pvc 102 | i cir
cir 128000 bc 12800 be 0 byte limit 1600 interval 100
mincir 64000 byte increment 1600 Adaptive Shaping none
Rack1R1#sh frame pvc 103 | i cir
cir 192000 bc 19200 be 0 byte limit 2400 interval 100
mincir 96000 byte increment 2400 Adaptive Shaping none
HTH,
__
Edison.
Hi Edison,
Thanks Edison, I had just worked that bit out, however, the above snippet gives me another question. You have both a static mapping and a dynamic mapping for your dlci 102 ???
Is this normal and either way what does 'sh frame map' indicate for the pvc ? i.e is it static or dynamic ?
Phil.
