ICND Test question
Mar 5th, 2008
Why would there be a question like this? I interpert it one way while cisco answers another.
Is this just me?
27. What CLI command should you enter to display the command syntax help so that you can see how to complete a command that begins with “config”?
answer is
config ?
and not
massimiliano.se... Wed, 03/05/2008 - 22:22
If you type configure? IOS helps you to complete the command.
If you type configure ? IOS tells you the option...network, terminal...and so on.
I hope this helps.
Best regards.
Istvan_Rabai Wed, 03/05/2008 - 22:32
Hi Bill,
"config?" would display all IOS commands that begin with the "config" character string.
"config ?" (with space before the ?) would display all the options of the "config " or "configure " command (i.e. the command syntax of the "config " command).
