VG248 swap out
Answered Question
Mar 5th, 2008
What do I need to do to swap out a VG248?
I conigures the IP address etc.., enabled the ports
Do I just configure the GW MAC address in CM and/or do I need to go into each DN and change the MAC as well?
Randall
Correct Answer by Rob Huffman about 9 years 1 month ago
Hi Randall,
Have a look at and make note of the specific settings on the VG (via console or telnet) before doing any changes. When you are ready you can go to the Device>Gateway Page on CCM and and change the MAC address from old to new and reset. You won't need to change the MAC for all the individual ports.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 03/05/2008 - 15:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Randall,
Hope this helps!
Rob
rcrumm_2 Wed, 03/05/2008 - 16:04
Thanks Rob,
That is what I thought. Just wanted to make sure.
Randall
Rob Huffman Wed, 03/05/2008 - 16:52
  • Hall of Fame,
    Founding Member
Hi Randall,
You are most welcome :)
Take care,
Rob
lwai Wed, 03/05/2008 - 19:09
Hi Randall,
I run the program in CM4.1(3) Pubscriber, it display"unable to locate mscoree.dll".
What CM version you are using? What stepes we use that program? please show us more information in details, thanks in advance!!!
Michael.
