Dropped calls in Call Manager 4.1
Jaime Valencia Wed, 03/05/2008 - 21:58
  • Cisco Employee,
  • Hall of Fame,
    2011
depending on the problem you would need not only SDI but also SDL if the phones are not on the same server.
traces are the only way to go as Nicolas says, also i can certainly tell you they're not user friendly if you have no experience with them
my advise would be to raise a TAC case on this
javalenc
