03-05-2008 02:54 PM - edited 03-05-2019 09:34 PM
Trying to set up a transparent SSL proxy from our CSS 11503 to 3 Microsoft IIS6 servers. Don't need sticky sessions as we are using an IMDB on a secondary network on the web servers so hitting any one will preserve session. All traffic uses SSL, no HTTP allowed.
Did the following:
1) ssl genrsa RSAkey1 1024 "pwd"
2) ssl associate rsakey RSA1 RSAkey1
3) ssl gencsr RSAkey1
4) copied CSR into Verisign MPKI portal and selected Microsoft as the OS (LB 3 IIS6 servers)
5) Concatenate Verisign Intermediate with cert returned from step 4
6) copy ssl sftp ssl_record import chainedcsrt.cer PEM "pwd"
7) ssl associate cert Cert1 chainedcert.cer
Response:
%% Not a valid key or certificate file
Tried with just base cert received from step 4 and get same error.
However, if I export one of the certs and private key from one of the Windows 2003 servers import it. This works:
1) copy ssl sftp ssl_record import mycert.pfx PKCS12 "pwd" "pwd"
2) ssl associate cert Cert1 mycert.pfx
3) ssl associate rsakey RSA1 mycert.pfx
show ssl assoc indicates all is well.
How do I install a cert generated entirely from the CSS by submitting the csr to Verisign? Do I need to pick a different OS option? There is nothing listed for a CSS although there are options for other load balancers...
-Eric
03-11-2008 02:43 PM
May be you enable the unwanted things make sure ie passphare etc.
03-12-2008 08:31 AM
I should also add that prior to this I ran through the same 7 steps above but in step (4) I used a Microsoft Windows Server 2003 Certificate Server to submit the CSR generated from the CSS and in step (5) I concatenated the root CA from the Certificate Server with the certificate generated from the CSR and successfully imported, set up the ssl associations, ssl-proxy-list, and had a working VIP.
Doing this validated the documented Cisco process but this same process fails when using the Verisign Managed PKI portal and I have yet to discover why.
I also tried changing the order of concatenation but that gave the same error.
03-18-2008 01:10 PM
eric,
You could try to pick the Sonicwall OS Option on verisign. We were able to use the CSR (generated from the CSS) using this option.
