Fan Part Numbers for Cisco 2801, 2821 and 2851 fans
Mar 5th, 2008
I have P/Ns for Cisco 2811 router fans as follows:
ACS-2811-FAN-1/2= and ACS-2811-FAN-3=
But I do not have part numbers for fans used in 2801, 2821 and 2851 routers.
Does anyone have these prt numbers?
It doesn't make sense to change the whole router for just a fan failure.
aghaznavi Tue, 03/11/2008 - 14:48
I think Fan modules are not replaceble. Full chassis need to be ordered if FANs are failing.
glen.grant Tue, 03/11/2008 - 14:57
Its not something most of us in here would do . It will certainly void any kind of warranty or maintenance contract on the device.
astanislaus Sun, 02/01/2009 - 21:12
ACS-2821-51-FANS= should be orderable from Cisco. Why should we replace the whole chassis as the previous reply suggests
aleonbad Wed, 04/09/2014 - 09:06
for the 2821 and 2851 routers the fan is the same : ACS-2821-51-FANS=
for 2801 the whole chassis needs to be replaced
