how much memory
Mar 5th, 2008
System restarted at 22:37:21 GMT Sun Sep 30 2007
System image file is "flash:c3845-ipvoice_ivs-mz.124-13b.bin"
Cisco 3845 (revision 1.0) with 1011712K/36864K bytes of memory.
Processor board ID FHK1042F3R3
2 Gigabit Ethernet interfaces
4 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
250880K bytes of ATA System CompactFlash (Read/Write)
How do you read/get the exact memory installed? thanks
