03-05-2008 10:01 PM - edited 03-15-2019 09:15 AM
Hi ,posted this question yesterday but it seems to have dissapeared ,we have 2 Call Managers ,1 main and 1 backup ,is it possible to change the cluster ID`s ,and if so what is the process and what will the impact be. Any help will be appreciated.
03-06-2008 02:08 AM
I think ClusterID is main used for CDR (call detail record) reporting purposes. It is saved in field in CDR record. It's useful if you have multiple clusters and want to merge billing data into one big database (warehouse or sth similar).
regards,
PK
03-06-2008 02:15 AM
We`ll some guy installed the Cisco Field Monitor software but he now apparently needs to change the cluster id`s of the call managers as according to him the field monitor software only recognizes one call manager per cluster ,but according to me the database on both call managers should be exactly the same ? Seeing as the one is a backup for the other.
03-06-2008 02:48 AM
Parent database is on publisher, Subscriber just have snapshot (read-only) from publisher. Cluster ID is clusterwide parameter.
regards,
PK
