03-05-2008 10:59 PM - edited 03-03-2019 09:00 PM
Dear All,
Please help me, i would like to configure ASA 5510.and i had DMZ , i want DMZ can access to inside and Inside can access to DMZ, but now it doesn't work.
Pleas see configuration in the attach file.
Best Regards,
Rechard,
03-05-2008 11:35 PM
Hi Rechard
Not sure what the static statements are doing
static (inside,dmz) 192.168.4.0 192.168.3.0 netmask 255.255.255.0
static (dmz,inside) 192.168.3.0 192.168.4.0 netmask 255.255.255.0
You only need a static for traffic from a lower to a higher level interface. Can you remove the above 2 statements, do a "clear xlate" and then add
static (inside,dmz) 192.168.3.0 192.168.3.0 netmask 255.255.255.0
and then retry.
Jon
03-06-2008 12:17 AM
03-06-2008 12:59 AM
hi,Rechard
please change ip address block of DMZ from 192.168.3.0 to 192.168.4.0
regards
dongdong
