vpn tuneel is working one way
Mar 5th, 2008
I have a cisco router and a junper firewall for site to site vpn on both there are multiple tunnels .
Now for the tuneel between the 2 it is working from router to juniper but not from juniper to router
sh cry ipsec sa and iskmp sa in router is ok
How do I trouble shoot
Any help is appreciated
Raj
massimiliano.se... Thu, 03/06/2008 - 00:50
The traffic from LAN (Juniper) to LAN (Cisco) is enabled to create an IPSEC SA with Cisco Router. In other words, is it interesting traffic?
I hope this helps,
Best regards.
Massimiliano.
rajbhatt Thu, 03/06/2008 - 04:07
have initiated a ping from router to juniper .Works great.
But if I ping from juniper to router the tunnel status T1 shows down
What are the possible things I should check other than cryto access lists
Raj
