material confirmation
Mar 5th, 2008
i have a customer need contact center for 100 agent .
i made the offer with this material :
Contact Center Software
CCX-60-NEW-ENH CCX 6.0 ENH Server , Seat Software
CCX-60-NEW-E CCX 6.0 ENH NON-HA Server , Seat Software
CCX-7845I-60 CCX 6.0 7845 IBM Server SW,OS
CCX-60ENH-SEAT1 CCX 6.0 ENH Seat Qty 1 (agent or supervisor)
Included: CCXIVR-W03-COA-KIT CCX and IP IVR COA Kit: Win2003 and COA
MCS-7845-I2-CCX1 HW Only MCS-7845-I2 with 4GB RAM and Four 72GB SAS HD
CAB-ACE Power Cord Europe
plz i need any one to confirm me is that offer is correct or not. does there any items that like license. does CCX 6 work with CM 6 . how can i order the the cisco agent desktop and supervisor.
to record the calls i have ordered the enhanced package . is that enough or i need any thing additional to make recording
pklos Thu, 03/06/2008 - 02:53
Supervisor uses the same license as agent, so don't worry about it. Cisco provides just simple ad-hoc recording, if you want real recording you should buy dedicated recording solution like NICE ( or Witness (
mostafamossad Thu, 03/06/2008 - 03:50
thx for reply
plz can u tell me what is new features in other record system .
and can i record the WAN calls using Contact center.
another question is there any limitation for ip phones supported by the contact center
