Stp
sham_chennala
How we can convert the port into blocking or listening or root port with the help of Stp? please give replay for this doubt.
thanks
Sham
Istvan_Rabai
Level 7
Level 7
Hi Sham,
There are several parameters that can be configured in STP that will determine the state of ports in the final stable spanning tree:
1. Switch priority: by configuring this value, you can control the selection of the root switch, which will partly influence which ports can be root ports on other switches.
2. Port cost: this will influence the selection of root ports, designated ports and blocked ports.
3. Port priority: this can also influence the selection of root ports, designated ports or blocked ports, when no other tie-breaking value is present.
There can be 100 pages written about this, depending on the level of detail one intends to write.
If you come up with a specific configuration, then I can help you sort out your configuration and control the port states.
Cheers:
Istvan
How we can define the port cost and port priority,in a switch which is the command used for configuring this?
Sham.
Hi Sham,
Both parameters have to be defined in interface configuration mode.
Port cost (1 to 65535):
spanning-tree cost xx
This will modify the port cost for all vlans.
spanning-tree vlan x cost yy
This will modify the port cost for vlan x.
Port priority (0 to 255):
spanning-tree port-priority xx
This will modify the port priority for all vlans.
spanning-tree vlan x port-priority yy
This will modify the port priority for vlan x.
Cheers:
Istvan
Have a look at this guide, it will take you through all necessary options
http://cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_35_se2/configuration/guide/swstp.html
Shaheen
