QoS on Fastethernet !!
Answered Question
Mar 6th, 2008
hi all, i have taken DSL connections from an ISP, consider 2 sites. Both are using ADSL connection terminated on their Fas 0/1 interfaces. The circuit taken is of 256 kpbs. now at each site we have a server that needs to be guaranteed 50% of bandwidth, now this is what i have done
configure interface bandwidth
int fas 0/1
bandwidth 256
service-policy output server
now here is the confusion, this qos will work only if there is congestion right ? so when there will be congestion of a 100mbps link ?? coz the circuit is 256 kpbs from DSL MODEM to ISP, the link from Fas 0/1 to MODEM is 100mbps, so router will send traffic at 100mbps to Modem right ? but when i issue the command
sh int fas 0/1
to see the load, it never exceeds 270-280 kpbs, so is the flow control between fas 0/1 and modem is limiting the traffic ?
To keep it simple, how shall i apply qos to Fas 0/1 in my case ?? CBWFQ will work when there is congestion its very difficult that 100mbps gets congested
i hope you understand what i am trying to ask,
kindly guide me through this
Correct Answer by Joseph W. Doherty about 9 years 4 months ago
As both Paolo and Mohamed correctly note, the key is a CBWFQ parent shaper that will limit your outbound FastEthernet to 256 Kbps. Within the child policy, you'll provide a class that guarantees the minimal bandwidth for your server.
e.g. (syntax likely incorrect)
ip access-list extended special_server
permit ip host x.x.x.x any
class-map special_server
match access-list special_server
policy-map parent_shaper
class class-default
shape 256000
policy child_priority
policy-map child_priority
class special_server
bandwidth percentage 50
interface fastethernet 1
service-policy output parent_shaper
Correct Answer by paolo bevilacqua about 9 years 4 months ago
The problem with config example is that won't work, because as the original posted, the 100mb interface is never congested.
The solution is using so called hierarchical policy, shape to the uplink value as needed, then apply llq or whatelse is desired.
See for example
http://cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800b2d29.shtml
Overall Rating: 5 (2 ratings)
kris_duffy Thu, 03/06/2008 - 04:01
Hi Illusion,
I believe the following will provide you with your basic needs. It could do with a bit further tuning but at this stage it is the best I can come up with. Once you have applied this config you can confirm it with - show policy-map interface fastEthernet 0/1
access-list 100 permit ip host {your server ip here} any
class-map match-all server-access
match access-group 100
policy-map server
class server-access
bandwidth 128
class class-default
bandwidth 128
int fas 0/1
Hope this helps,
Kris
Correct Answer
paolo bevilacqua Thu, 03/06/2008 - 05:58
  • Hall of Fame,
    Founding Member
See for example
Mohamed Sobair Thu, 03/06/2008 - 06:39
  • Gold, 750 points or more
the bandwidth configured under the interface would not change the interface operating speed. The bandwidth is used for routing protocol & QoS calculation.
once you configured bandwidth, you could then apply you QoS based on it, or if you want to limit the speed, you could configure
shaping) and apply CB/WFQ using parent/child policy.
Mohamed
Mohamed
Correct Answer
Joseph W. Doherty Thu, 03/06/2008 - 07:06
class class-default
shape 256000
david.lima Thu, 03/06/2008 - 09:33
I cannot applyt this on a 4506, can i use the police command instead of shape ?
paolo bevilacqua Thu, 03/06/2008 - 12:40
  • Hall of Fame,
    Founding Member
Not really, the police command will have adverse effects on tcp performance, remember that anything but a true router is not be suites to handle wan things and related qos.
At that point better to leave things as they are and if the voice cant go properly, get a router where you fit the adsl interface and you will have complete control over outgoing QoS.
Joseph W. Doherty Thu, 03/06/2008 - 13:57
From my reading of the 4500 series QoS documentation, 12.2(40)SG, depending on your sup, up to 4 queues are supported per interface. You have the option to shape a rate against each tx queue.
With such support, you could direct the special server traffic to one queue with a 128 Kbps shaper and all other traffic to another queue, also with a 128 Kbps shaper. This would meet your minimal requirements.
One issue is any excess bandwidth not used by one queue could not be used by the other queue.
david.lima Fri, 03/07/2008 - 05:39
Thank You, I also read this documentation but it seems that I cannot do shaping (I have SUP V card). My goal is to define a main class with the WAN bandwith that my provider gives to me and then declare subclasses with percent of the main class.My provider brings the WAN link with a copper to fiber transceiver directly connected to a Gigabit interface (@100 Mbs) of my 4500. If i declare percent of tx-queue without parent class it does not apply cause my interface is @100mbps
Joseph W. Doherty Fri, 03/07/2008 - 05:50
Perhaps the only way you're going to meet your goal is to place a full featured WAN router between the 4500 and your copper WAN link. It doesn't have to be a "monster" box, only one that can handle the bidirectional bandwidth. 256 Kbps is trivial, assuming the downlink speed is 8 Mbps or less, an 800 or 1800 series might do (I'm uncertain about the features of 800s).
