Multiple vlan with multiple SSID
Mar 6th, 2008
I have a 1130 AP connected to a 500 series express catalyst switch. I want to have two vlans one for guest internet access only and the other that can have both internet and internal access. I want to have two SSID one for guest and the other for internal employee which should match the vlan. Can anyone guide me to a good doc. that can help me implement this solution. And is the 500 series switch is capable of doing this.
Thanks.
rghernandez Thu, 03/06/2008 - 03:31
To anwser your first question Yes your 500 series switch is capable of doing vlans (See Link: "http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6545/product_data_sheet0900aecd80322aeb.html") (first time pasting a link sorry if it doesnt work) here is another link that you can utilize on config examples. and as for you access point you can do the same as well (http://cisco.com/en/US/products/ps6087/tsd_products_support_configure.html)
