hello,
I think it is available on this router.
Enter this command.
show flash:
the following files should be present on your router flash.
3 -rwx 2254 Mar 1 2002 00:03:18 +00:00 sdmconfig-8xx.cfg
4 -rwx 833024 Mar 1 2002 00:03:36 +00:00 es.tar
5 -rwx 1052160 Mar 1 2002 00:03:56 +00:00 common.tar
6 -rwx 1038 Mar 1 2002 00:04:07 +00:00 home.shtml
7 -rwx 102400 Mar 1 2002 00:04:19 +00:00 home.tar
8 -rwx 491213 Mar 1 2002 00:04:34 +00:00 128MB.sdf
if not you need you need to install SDM software onto your router flash.
ilnaiduccna Thu, 03/06/2008 - 07:35
The below fallowing files are present on my router flash is they ok to enable sdm and plz. tell how to enable sdm on 2800R.
Router#sh flash:
-#- --length-- -----date/time------ path
1 17770796 Apr 17 2006 08:55:50 +05:30 c2800nm-entbase-mz.123-14.T7.bin
2 1646 Apr 17 2006 09:04:20 +05:30 sdmconfig-2811.cfg
3 4052480 Apr 17 2006 09:04:48 +05:30 sdm.tar
4 812032 Apr 17 2006 09:05:02 +05:30 es.tar
5 1007616 Apr 17 2006 09:05:18 +05:30 common.tar
6 1038 Apr 17 2006 09:05:32 +05:30 home.shtml
7 113152 Apr 17 2006 09:05:46 +05:30 home.tar
8 511939 Apr 17 2006 09:06:00 +05:30 128MB.sdf
Naidu.
