6509 Switch& FWSM&firewall vlan-group
Mar 6th, 2008
Hi all,
We create new VLANs & will assign these VLANs to the Firewall Services Module
By using the below command:-
(Config)# Firewall vlan-group firewall_group vlan_range
My question is there any need to restart the FWSM after adding new vlan into vlan group??
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 03/06/2008 - 05:18
No you don't have to reboot anything. Just make sure if you are running a pair in separate chassis that you update both firewall vlan-group entries on both 6500's because if they become out of sync then failover will not work.
Jon
